주요 콘텐츠로 건너뛰기
Samsung Galaxy Prime Battery Replacement
필요한 것
  1. Samsung Galaxy Prime Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Insert a small spudger or fingernail into the tab that is located on the power button side of the phone and then try to pry up.
    • After the initial lift, go around the edges of the back cover lifting it up to release.
  2. Samsung Galaxy Prime Battery Replacement: 2 단계, 이미지 1/1
    • To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
  3. Samsung Galaxy Prime Battery Replacement: 3 단계, 이미지 1/1
    • Insert the new battery in the reverse order from taking out the battery, ensuring the metal contacts from the phone are touching the flat metal contacts on the battery. Then place another edge of battery in the bay.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Khristina Manivanh
회원 가입일: 07/13/18
150 평판
안내서 1개 작성함
UW Tacoma, Team S1-G1, Liner Summer 2018 UW Tacoma, Team S1-G1, Liner Summer 2018 회원
UWT-LINER-SU18S1G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 37
전체 시간: 1,412
