필요한 것
Insert an opening tool or fingernail into the tab on the power button side of the phone.
Lift on the tab to pry the back cover off of the phone.
Continue to pry off the back all around the edges of the phone until the entire cover is fully removed.
To remove the battery, lift up on the thumb tab located on the bottom right corner of battery bay.
To remove the SD card and Sim card, look above the battery bay and slide the card out.
Insert an opening tool to lift up and the plastic plate that covers the LCD ribbon cable and remove it.
Use a size PH000 Phillips screwdriver to unscrew the nine screws located on the back.
Use a heat gun or a heating device to lightly heat the edges of the screen on the phone
Insert an opening tool between the screen and plastic bezel, then apply pressure to separate.
Use a plastic spudger to disconnect the ribbon cable from the motherboard.
The camera will be free to remove.
Use a plastic spudger to disconnect LCD ribbon cable and front facing sensor.
