주요 콘텐츠로 건너뛰기
Samsung Galaxy R Motherboard Replacement
필요한 것
  1. Samsung Galaxy R Motherboard Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Samsung Galaxy R Motherboard Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Samsung Galaxy R Motherboard Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Motherboard Replacement, Battery: 2 단계, 이미지 3개 중 1개 Samsung Galaxy R Motherboard Replacement, Battery: 2 단계, 이미지 3개 중 2개 Samsung Galaxy R Motherboard Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Motherboard Replacement, Screws: 3 단계, 이미지 2개 중 1개 Samsung Galaxy R Motherboard Replacement, Screws: 3 단계, 이미지 2개 중 2개
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Motherboard Replacement, Bottom Panel: 4 단계, 이미지 3개 중 1개 Samsung Galaxy R Motherboard Replacement, Bottom Panel: 4 단계, 이미지 3개 중 2개 Samsung Galaxy R Motherboard Replacement, Bottom Panel: 4 단계, 이미지 3개 중 3개
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Lift the bottom panel off the back of the phone.
  5. Samsung Galaxy R Motherboard Replacement, Top Panel: 5 단계, 이미지 3개 중 1개 Samsung Galaxy R Motherboard Replacement, Top Panel: 5 단계, 이미지 3개 중 2개 Samsung Galaxy R Motherboard Replacement, Top Panel: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to grasp the circular silver metal piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Motherboard Replacement, Remove Motherboard: 6 단계, 이미지 1개 중 1개
    • If you want to replace motherboard, gently pull motherboard from the back of the phone.
    • The parts indicated in red color are attached by adhesive to the back of the phone, so more force will be necessary to remove these areas.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Keon Horahan
회원 가입일: 10/13/14
841 평판
안내서 6개를 작성함
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 회원
CLEM-BENSON-F14S3G3
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 36
지난 30일: 137
전체 시간: 2,487
