주요 콘텐츠로 건너뛰기
Samsung Galaxy R SIM Card Replacement
필요한 것
  1. Samsung Galaxy R SIM Card Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy R SIM Card Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy R SIM Card Replacement, Rear Case: 1 단계, 이미지 3/3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R SIM Card Replacement, Battery: 2 단계, 이미지 1/3 Samsung Galaxy R SIM Card Replacement, Battery: 2 단계, 이미지 2/3 Samsung Galaxy R SIM Card Replacement, Battery: 2 단계, 이미지 3/3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R SIM Card Replacement, Remove screws: 3 단계, 이미지 1/2 Samsung Galaxy R SIM Card Replacement, Remove screws: 3 단계, 이미지 2/2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Carefully remove mid-frame from the front panel.
  4. Samsung Galaxy R SIM Card Replacement, SIM Card: 4 단계, 이미지 1/3 Samsung Galaxy R SIM Card Replacement, SIM Card: 4 단계, 이미지 2/3 Samsung Galaxy R SIM Card Replacement, SIM Card: 4 단계, 이미지 3/3
    • Remove or replace SIM Card by pushing into metal slot above the battery holder.
결론
Keon Horahan
회원 가입일: 10/13/14
841 평판
안내서 6개 작성하였습니다
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 회원
CLEM-BENSON-F14S3G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 2,453
