주요 콘텐츠로 건너뛰기
Samsung Galaxy R Speaker Assembly Replacement
필요한 것
  1. Samsung Galaxy R Speaker Assembly Replacement, Rear Case: 1 단계, 이미지 3개 중 1개 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: 1 단계, 이미지 3개 중 2개 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: 1 단계, 이미지 3개 중 3개
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Speaker Assembly Replacement, Battery: 2 단계, 이미지 3개 중 1개 Samsung Galaxy R Speaker Assembly Replacement, Battery: 2 단계, 이미지 3개 중 2개 Samsung Galaxy R Speaker Assembly Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Speaker Assembly Replacement, Remove screws: 3 단계, 이미지 2개 중 1개 Samsung Galaxy R Speaker Assembly Replacement, Remove screws: 3 단계, 이미지 2개 중 2개
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: 4 단계, 이미지 3개 중 1개 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: 4 단계, 이미지 3개 중 2개 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: 4 단계, 이미지 3개 중 3개
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Gently lift the bottom panel from the back of the phone.
  5. Samsung Galaxy R Speaker Assembly Replacement, Top Panel: 5 단계, 이미지 3개 중 1개 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: 5 단계, 이미지 3개 중 2개 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to grasp the vibrator piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Speaker Assembly Replacement, Speaker: 6 단계, 이미지 3개 중 1개 Samsung Galaxy R Speaker Assembly Replacement, Speaker: 6 단계, 이미지 3개 중 2개 Samsung Galaxy R Speaker Assembly Replacement, Speaker: 6 단계, 이미지 3개 중 3개
    • The speaker is located near the top of the phone underneath the motherboard circled in red.
    • To remove the speaker, gently pull on the strap attached until it releases from the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Daniel Hawkins
회원 가입일: 10/13/14
334 평판
안내서 2개를 작성함
Clemson, Team 3-3, Benson Fall 2014 Clemson, Team 3-3, Benson Fall 2014 회원
CLEM-BENSON-F14S3G3
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 572
