주요 콘텐츠로 건너뛰기
Samsung Galaxy Rush Front Camera Replacement
필요한 것
  1. Samsung Galaxy Rush Front Camera Replacement, Front Camera: 1 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement, Front Camera: 1 단계, 이미지 2/2
    • Looking at the back of your phone, use your finger to remove back cover.
  2. Samsung Galaxy Rush Front Camera Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement: 2 단계, 이미지 2/2
    • Remove the battery,
  3. Samsung Galaxy Rush Front Camera Replacement: 3 단계, 이미지 1/1
    • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
  4. Samsung Galaxy Rush Front Camera Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement: 4 단계, 이미지 2/2
    • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
  5. Samsung Galaxy Rush Front Camera Replacement: 5 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, gently lift connectors from motherboard.
    • A connector will be on the upper left
    • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
  6. Samsung Galaxy Rush Front Camera Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement: 6 단계, 이미지 2/2
    • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
    • These stay attached to the motherboard so be careful not to break them.
    • They are on the side of the phone.
  7. Samsung Galaxy Rush Front Camera Replacement: 7 단계, 이미지 1/1
    • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
  8. Samsung Galaxy Rush Front Camera Replacement: 8 단계, 이미지 1/1
    • Lift the motherboard upwards separating it from your screen.
  9. Samsung Galaxy Rush Front Camera Replacement: 9 단계, 이미지 1/1
    • Hold motherboard so that the circuits face away from you
    • Pop off the two black tabs on the upper most part of the motherboard.
  10. Samsung Galaxy Rush Front Camera Replacement: 10 단계, 이미지 1/1
    • Flip the motherboard over so that the circuits are now facing your direction.
  11. Samsung Galaxy Rush Front Camera Replacement: 11 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement: 11 단계, 이미지 2/2
    • Lift and remove the connecting tab
  12. Samsung Galaxy Rush Front Camera Replacement: 12 단계, 이미지 1/2 Samsung Galaxy Rush Front Camera Replacement: 12 단계, 이미지 2/2
    • Gently take the front camera with two fingers and pull upwards. A wiggle may help.
결론
Matthew
회원 가입일: 10/22/14
1 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 189
