주요 콘텐츠로 건너뛰기
Samsung Galaxy Rush Motherboard Replacement
필요한 것
  1. Samsung Galaxy Rush Motherboard Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy Rush Motherboard Replacement, Rear Case: 1 단계, 이미지 2/2
    • Looking at the back of your phone, use your finger to remove back cover.
  2. Samsung Galaxy Rush Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Galaxy Rush Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
  3. Samsung Galaxy Rush Motherboard Replacement: 3 단계, 이미지 1/1
    • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
  4. Samsung Galaxy Rush Motherboard Replacement: 4 단계, 이미지 1/2 Samsung Galaxy Rush Motherboard Replacement: 4 단계, 이미지 2/2
    • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
  5. Samsung Galaxy Rush Motherboard Replacement, Connectors: 5 단계, 이미지 1/2 Samsung Galaxy Rush Motherboard Replacement, Connectors: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, gently lift connectors from motherboard.
    • A connector will be on the upper left
    • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
  6. Samsung Galaxy Rush Motherboard Replacement: 6 단계, 이미지 1/2 Samsung Galaxy Rush Motherboard Replacement: 6 단계, 이미지 2/2
    • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
    • These stay attached to the motherboard so be careful not to break them.
    • They are on the side of the phone.
  7. Samsung Galaxy Rush Motherboard Replacement: 7 단계, 이미지 1/1
    • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
  8. Samsung Galaxy Rush Motherboard Replacement: 8 단계, 이미지 1/1
    • Lift the motherboard upwards separating it from your screen.
  9. Samsung Galaxy Rush Motherboard Replacement, Motherboard: 9 단계, 이미지 1/1
    • At this point your motherboard is separated from the screen.
  10. Samsung Galaxy Rush Motherboard Replacement: 10 단계, 이미지 1/1
    • Just swap in the new motherboard and reassemble.
결론
Kenny Afiadata
회원 가입일: 10/20/14
34 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 383
