주요 콘텐츠로 건너뛰기
Samsung Galaxy S Blaze Display Assembly Replacement
필요한 것
  1. Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: 1 단계, 이미지 1/3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: 1 단계, 이미지 2/3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: 1 단계, 이미지 3/3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Samsung Galaxy S Blaze Display Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Samsung Galaxy S Blaze Display Assembly Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S Blaze Display Assembly Replacement: 3 단계, 이미지 2/2
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  4. Samsung Galaxy S Blaze Display Assembly Replacement: 4 단계, 이미지 1/3 Samsung Galaxy S Blaze Display Assembly Replacement: 4 단계, 이미지 2/3 Samsung Galaxy S Blaze Display Assembly Replacement: 4 단계, 이미지 3/3
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
  5. Samsung Galaxy S Blaze Display Assembly Replacement, Display Assembly: 5 단계, 이미지 1/1
    • Gently remove the 2 ribbon cables as shown.
    • Connect the new screen to the main motherboard just the same way it was connected before.
    • Be careful not to crimp or bend the ribbon cables, as this will ruin the replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dustin
회원 가입일: 03/12/14
1,213 평판
안내서 6개 작성하였습니다
University of Maryland, Team 6-2, Vijaybhaskar Spring 2014 University of Maryland, Team 6-2, Vijaybhaskar Spring 2014 회원
UMD-VIJAYBHASKAR-S14S6G2
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,158
