주요 콘텐츠로 건너뛰기
Samsung Galaxy S Blaze Motherboard Replacement
필요한 것
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S Blaze Motherboard Replacement: 3 단계, 이미지 2/2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: 4 단계, 이미지 1/1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Galaxy S Blaze Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Galaxy S Blaze Motherboard Replacement: 5 단계, 이미지 3/3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: 6 단계, 이미지 1/1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
결론
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
다른 3명이 해당 안내서를 완성하였습니다.
Rene Bolanos
회원 가입일: 03/05/15
435 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 11-1, Blackburne Winter 2015 Sam Houston State, Team 11-1, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 803
