주요 콘텐츠로 건너뛰기
소개
If you have a Samsung GALAXY SII with broken Touchscreen or LCD Display, this manual will guide, how to change them.
This procedure is very hard. You must have good experience to do this !!!
Same steps you can use for replacing Touchscreen&LCD display with frame. This operation is more easy. If you haven't enough experience, I strongly recommend you, to choose this variant.
_______Video manual_______
동영상 개요
  1. We have a Samsung Galaxy S II with broken screen. We have a Samsung Galaxy S II with broken screen.
    • We have a Samsung Galaxy S II with broken screen.
  2. Remove your battery, the SIM card and the SD card. Remove the 7 screws highlighted in red. Remove the 7 screws highlighted in red.
    • Remove your battery, the SIM card and the SD card.
    • Remove the 7 screws highlighted in red.
  3. Use a plastic tool to remove the rear housing. Use a plastic tool to remove the rear housing. Use a plastic tool to remove the rear housing.
    • Use a plastic tool to remove the rear housing.
  4. The mother board is held by 2x screws. Remove them. The mother board is held by 2x screws. Remove them.
    • The mother board is held by 2x screws. Remove them.
  5. Remove the cables that are highlighted in red, before continuing to the screen. Remove the cables that are highlighted in red, before continuing to the screen. Remove the cables that are highlighted in red, before continuing to the screen.
    • Remove the cables that are highlighted in red, before continuing to the screen.
  6. Release the side buttons. The arrow will point you to where they are. Release the side buttons. The arrow will point you to where they are. Release the side buttons. The arrow will point you to where they are.
    • Release the side buttons. The arrow will point you to where they are.
  7. Careful release the motherboard from it's housing. Careful release the motherboard from it's housing.
    • Careful release the motherboard from it's housing.
  8. At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing. We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
    • At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
    • We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
    • Use a hot air to soften the adhesive enough to remove the glass.
  9. With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame. With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame. With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
    • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
  10. Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame. Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame. Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
    • Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
  11. Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury. Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury. Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
    • Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
  12. Clean the frame from the remains of tape. Clean the frame from the remains of tape. Clean the frame from the remains of tape.
    • Clean the frame from the remains of tape.
  13. Test the new spare part before reassembling. Test the new spare part before reassembling. Test the new spare part before reassembling.
    • Test the new spare part before reassembling.
  14. Install the LCD&Digitiser on it's housing. Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model. Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
    • Install the LCD&Digitiser on it's housing.
    • Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
  15. To reassemble your device, follow these instructions in reverse order. To reassemble your device, follow these instructions in reverse order. To reassemble your device, follow these instructions in reverse order.
    • To reassemble your device, follow these instructions in reverse order.
결론
다른 31명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
178,835 평판
안내서 315개 작성하였습니다
Master Techs Master Techs 회원
Community
297 회원들
안내서 983개 작성하였습니다
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
Edward Weissbard - 답글
Yes, removing the glass is very difficult and you must have some experience from before.
ZFix - 답글
To moderators: please un-archive this guide: there's no replacement or "updated version of the guide" among the current guides.
yurkennis - 답글
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
Frederic Morelli - 답글
how much the cost in replacement display with fame.....samsung galaxy s2
Bhola Shrestha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 52
전체 시간: 97,367
