주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S II Screen Replacement
필요한 것
  1. Samsung Galaxy S II Screen Replacement, Remove back cover: 1 단계, 이미지 1개 중 1개
    • Gently remove the back cover starting from the slot given on the right side.
  2. Samsung Galaxy S II Screen Replacement, Remove battery: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the battery from the slot.
    • Carefully place the battery away from some hot object or fire.
  3. Samsung Galaxy S II Screen Replacement, Remove back case screws: 3 단계, 이미지 1개 중 1개
    • Use a magnetic philips #0 head screw driver to open the 7 x 1/16 in (1.6 mm) philips head screws shown in the image.
    • Place the screws carefully in a box.
  4. Samsung Galaxy S II Screen Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S II Screen Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S II Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Gently unlock the snap locks starting from the top left corner and progressing along the perimeter to remove the back case.
    • To unlock the snaps, apply force close to the snap in order to avoid cracking of the plastic cover.
    • Remove the plastic cover carefully and place on the white paper.
  5. Samsung Galaxy S II Screen Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Use a screwdriver or another pointed tool to disconnect the screen connector.
    • Lift the cable out of the slot.
    • Gently handle the cable to avoid damage to the cable or the connector.
  6. Samsung Galaxy S II Screen Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the connector for the speaker and audio jack carefully.
    • Gently lift the cable to avoid damage to the cable or the connector.
  7. Samsung Galaxy S II Screen Replacement: 7 단계, 이미지 3개 중 1개 Samsung Galaxy S II Screen Replacement: 7 단계, 이미지 3개 중 2개 Samsung Galaxy S II Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Use a screwdriver to gently lift the speaker which is fixed to the base with double side tape.
    • Gently lift the earpiece using a flat screwdriver.
  8. Samsung Galaxy S II Screen Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy S II Screen Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy S II Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Unplug the secondary camera connector carefully and lift the cable.
    • Then unplug the connector that receives the input from the screen.
    • Remove the connection for the charging port using a screw driver.
    • Handle carefully to avoid tearing off the cable.
  9. Samsung Galaxy S II Screen Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the two 1.6 mm black head screws using the Phillips #00 screwdriver.
  10. Samsung Galaxy S II Screen Replacement: 10 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the antennae from both the ends by removing the connections using flat screwdriver.
    • Carefully pull out the antennae cable from the slot.
  11. Samsung Galaxy S II Screen Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Gently peel off the power button fixed with double adhesive tape.
    • Carefully lift the button out of the slot.
    • Try to keep the double side tape on the button and handle the cable carefully to avoid tearing the ribbon.
  12. Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: 12 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: 12 단계, 이미지 2개 중 2개
    • Repeat the same procedure from step 15 to remove the volume up down button.
  13. Samsung Galaxy S II Screen Replacement, Remove main board: 13 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement, Remove main board: 13 단계, 이미지 2개 중 2개
    • Now the main board is free. Carefully lift it up and place on the workbench gently.
  14. Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: 14 단계, 이미지 2개 중 1개 Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: 14 단계, 이미지 2개 중 2개
    • Peel off the ribbon cable connecting the charging port and microphone by hand.
  15. Samsung Galaxy S II Screen Replacement, Unscrew charging module: 15 단계, 이미지 1개 중 1개
    • Remove the two 2.0 mm screws using the Phillips #0 screwdriver.
  16. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: 16 단계, 이미지 3개 중 1개 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: 16 단계, 이미지 3개 중 2개 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: 16 단계, 이미지 3개 중 3개
    • Lift the microphone gently.
    • Lift the board out from the metal casing and place on the workbench.
  17. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: 17 단계, 이미지 3개 중 1개 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: 17 단계, 이미지 3개 중 2개 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: 17 단계, 이미지 3개 중 3개
    • Finally push the screen out applying force through the screwdriver at the highlighted locations.
    • Take out the screen, clean the remaining double side tape and adhesive.
    • Install the new screen and follow the same steps in reverse order to re assemble the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bader
회원 가입일: 04/16/20
337 평판
안내서 1개를 작성함
1가이드 댓글
My Samsung Galaxy s2 is an AT&T phone
Anthony Godoy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 49
전체 시간: 2,763
