주요 콘텐츠로 건너뛰기
Samsung Galaxy S II T989 Media Card Replacement
  1. Samsung Galaxy S II T989 Media Card Replacement, Rear Cover: 1 단계, 이미지 1/3 Samsung Galaxy S II T989 Media Card Replacement, Rear Cover: 1 단계, 이미지 2/3 Samsung Galaxy S II T989 Media Card Replacement, Rear Cover: 1 단계, 이미지 3/3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Media Card Replacement, Media Card: 2 단계, 이미지 1/3 Samsung Galaxy S II T989 Media Card Replacement, Media Card: 2 단계, 이미지 2/3 Samsung Galaxy S II T989 Media Card Replacement, Media Card: 2 단계, 이미지 3/3
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua King
회원 가입일: 03/26/14
1,378 평판
안내서 9개 작성하였습니다
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 회원
CLEM-BENSON-S14S1G5
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 465
