주요 콘텐츠로 건너뛰기
Samsung Galaxy S II T989 Speaker Replacement
필요한 것
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 1 단계, 이미지 1/3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 1 단계, 이미지 2/3 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 1 단계, 이미지 3/3
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 2 단계, 이미지 1/3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 2 단계, 이미지 2/3 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. Samsung Galaxy S II T989 Speaker Replacement: 3 단계, 이미지 1/3 Samsung Galaxy S II T989 Speaker Replacement: 3 단계, 이미지 2/3 Samsung Galaxy S II T989 Speaker Replacement: 3 단계, 이미지 3/3
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Samsung Galaxy S II T989 Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joshua King
회원 가입일: 03/26/14
1,363 평판
안내서 9개 작성하였습니다
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 회원
CLEM-BENSON-S14S1G5
4 회원들
안내서 9개 작성하였습니다
댓글 3개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,490
