주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S II T989 Speaker Replacement
필요한 것
  1. Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 1 단계, 이미지 3개 중 1개 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 1 단계, 이미지 3개 중 2개 Samsung Galaxy S II T989 Speaker Replacement, Rear Cover: 1 단계, 이미지 3개 중 3개
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S II T989 Speaker Replacement, Inner Plate: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • The inner plate is held on by six screws that are 1/16 of an inch (1.6 mm).
    • Remove the screws with a Philips head precision screwdriver.
    • Place all screws someplace that they will not easily be lost, such as a magnetic mat or a plastic bag.
  3. Samsung Galaxy S II T989 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S II T989 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S II T989 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • When removing the inner plate, place device on grounded surface or use anti static wrist band.
    • After the screws have been removed, the only thing holding the inner plate in is several plastic tabs built into the frame of the phone.
    • Firmly pinch the edge, as shown in the picture, and pull the plate away from the frame.
    • If you cannot get a grip on the inner plate, consider using the spudger to pry and lift the plate out.
  4. Samsung Galaxy S II T989 Speaker Replacement, Speaker: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S II T989 Speaker Replacement, Speaker: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S II T989 Speaker Replacement, Speaker: 4 단계, 이미지 3개 중 3개
    • The speaker is located in the area located by the red rectangle.
    • To remove the speaker hold the frame with one hand then push the speaker out with the other.
    • It may take a large amount of force so be careful to hold the frame to prevent it from breaking.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Joshua King
회원 가입일: 03/26/14
1,378 평판
안내서 9개를 작성함
Clemson, Team 1-5, Benson Spring 2014 Clemson, Team 1-5, Benson Spring 2014 회원
CLEM-BENSON-S14S1G5
4 회원들
안내서 9개를 작성함
3가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 34
전체 시간: 1,724
