주요 콘텐츠로 건너뛰기
Samsung Galaxy S III Battery Replacement
필요한 것
  1. Samsung Galaxy S III Battery Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement, Rear Case: 1 단계, 이미지 2/2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Battery Replacement: 2 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement: 2 단계, 이미지 2/2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Battery Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement: 3 단계, 이미지 2/2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Battery Replacement: 4 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement: 4 단계, 이미지 2/2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Battery Replacement: 5 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement: 5 단계, 이미지 2/2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
    very easy to follow instructions clear and concise
    Deric JONES - 답글
  6. Samsung Galaxy S III Battery Replacement, Battery: 6 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement, Battery: 6 단계, 이미지 2/2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Battery Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S III Battery Replacement: 7 단계, 이미지 2/2
    • Remove the battery.
결론
다른 90명이 해당 안내서를 완성하였습니다.
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 3개
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - 답글
Super simple. Thanks!
bmwherry - 답글
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 68
전체 시간: 64,674
