소개
Use this guide to replace the motherboard.
필요한 것
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Lift up and remove the rear case from the phone.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
What would you use to remove the screws
I used both P#000 and J#00 precision bits to good effect. I tend to prefer the Japanese Standard bits in place of Philips, as the JIS bits seem not to cam out and strip screws as easily.
E West -
Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
I had to use a guitar-pick to pry that section off of the frame. Start at the front-facing camera edge and run the pick underneath the plastic cover. The catches should release.
READ ME!
For a guide that takes you step by step on how to remove the SIM and microSD, I'm surprised they didn't mention the top part of this midframe (still attached, in the pictures). This top part of the midframe also needs to be removed before you can take out the motherboard.
You need to disconnect a ribbon not listed in these directions first, then pry that midframe up with the help of a guitar pick. This ribbon is located by the back-camera, next to the digitizer ribbon. This ribbon is connected to the midframe so it is essential you disconnect this before lifting the frame up.
The frame is really snapped in there so don't be afraid to use a little force - for reference, you will use more force to pull this frame off than you did to pull off the back-cover of the phone. Once this piece is off, your phone should look like the picture in step 14.
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
This is not a rear facing camera connector. This is the connector for the lHeadphone Jack/Speaker Assembly
You're right I
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
Step 18 says the front digitizer connector, but later calls it the earpiece/buttons/ambient light sensor ribbon cable.
Is the Digitizer connector part of the display connector, or is it elsewhere?
It's the volume and speaker
Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
Gently move the cable out of the way of the motherboard.
Be very careful,as it is very easy to break the connector off the motherboard.
Has anyone tried just folding the motherboard back to the left after removing all the screws WITHOUT disconnecting the wi-fi antenna? I'm just a little worried about this one step.
Folding the motherboard back without disconnecting the WiFi antenna worked for me! :)
Alec -
I broke the WiFi antenna connector bit off motherboard. How do I fix it?
Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
If I am not mistaking, there is a screw also on the motherboard needs to be removed before removing motherboard from the assembly
It's covered in Step 21
Amy Losh -
Use a plastic opening tool to pry the rear-facing camera connector from its socket.
The motherboard remains.
Where is the IC which is the responsible of charging and discharging?, cuz my phone's battery drops very fast! and I have to change this IC
다른 269명이 해당 안내서를 완성하였습니다.
댓글 42개
Between step 13 and 14, there should be a step to detach the cable to the camera lens and speaker assembly and the removal of the assembly.
The are usually $100 and Galaxy S III (Verizon) Motherboard
Where do i buy the original motherboard and what is the cost
I have a motherboard of samsung galaxy s3 sgh-t999 t mobile pm me here's my email tan.jeffrey84@yahoo.com for more info
Cheapest place to buy them is ebay.
I need Mother board for S3. If anyone have then contact idris.dw@gmail.com
I have a samsung sgh-t999 board pm me if u want tan.jeffrey84@yahoo.com
Can you please suggest where can I get the replacement parts for my S3 Korean version
I followed the instructions to a tee. Trying to save my old info/motherboard from my galaxy III that has a smashed screen, so I bought a used one and put my old motherboard in it. Everything went perfectly except the most essential thing - the on/off switch for the phone doesn't match up anymore. There's no way for me to turn on my phone on or off unless I go through steps 1-14 and proceed to use a needle to turn it on. I might as well use both phones as door stops now. If anyone wants a motherboard or 2 feel free to contact me before I chuck 'em over a cliff.
hey i am looking for a motherboard, pls drop a mail at mshah0510@yahoo.com
mihirs9 -
Do yo have a extra motherboard, mine will turn my phone on then instantly turn off but it will charger batteries, it will vibrate and light up all the time it has slight water damage too a spot I have taken it apart a dozen times. It's a galaxy s3 how much would you want for it.darrinpease@Gmail. Com
hello! we are missing a step between 13 and 14. the top portion of the cover which is the speaker assembly!
I samsung s3 having a problem, I need help fix it. thanks Ayub
I have a i9305 with broken glass and a i9300 in perfect shape. is it possible just to replace the motherboard in the i9300 with the i9305 (to get more RAM and LTE support?) or should the antennas and more (?) also be replaced?
Hi!
I want to do the same.
Have you tried it? Is it worked?
No, FRAMES ARE INCOMATIBLE
Hi, will a i9301 (s3 neo) motherboard fit into a i9300 (regular s3) case?
No,
You need to modificate the frame (verrrrrry diiiifiiicult)
Or separate screen from frame
(FRAMES ARE INCOMPATIBLE)
How can you tell which mother board you need there is like 5 different motherboards up there ?
How do I know what motherboard I need there is about 5 up there and I don't know which one it is ?
I need Mother board for S3 I9300. If anyone have them contact Shovokhan55@gmail.com
I need Mother board for S3 I9300. If anyone have them contact Shovo201372@yahoo.com
Need SGS3 T999 I747 phone to put my motherboard in. Any color. LCD and glass must be good.
I would like to add my experience with a motherboard replacement with Sprint. I bought a replacement SPH-L710 motherboard through iFixit.com's website. The motherboard was sealed in an electrostatic bag; however, upon opening the bag I noticed the SD card reader had signs of slight wear/scratches on the component. Other than that, product was fine. Replacement and install went off without a hitch. Booting up revealed a fully wiped, Knox enabled OS.
After calling Sprint to activate the phone, they informed me the IMEI/ESN number was not valid due to it being already activated through another carrier. They will flat out refuse to activate it. So, to sum up, be careful when replacing GS3 motherboards as the replacement may be on Sprint's internal blacklist even though sites like Swappa.com will tell you that the IMEI/ESN number is fine.
I was able to switch the motherboards of two phones following these steps. Thanks very much for providing these.
My Repair is for a tablet not a phone
Hy I Need Galaxy s3 i9305 lte Motherboard My Email is rj.abid1@yahoo.com
screw size #0 in instructions but #00 screwdriver is needed. Why?
Jack Smith - 답글
Hey Jack, #0 might work, but the #00 should be the best fit. The guide has been updated to reflect this.
Hi, I need a working logic board for S3, AT&T. The charging connector on mine broke. The phone still works. Currently charging the phone with a wireless charging module adapter which doesnt make contact reliably and is inytermittent. was wondering changing the board would be a cheaper option. When you use a new Logic board i suppose the phone’s old IMEI is no longer good. Is that True.
Any one with a logic board please e-mail me at trcengineer@yahoo.com
Samsung s3 board ma network i.c problem ha I.c Chang Kara ka doga
Battery charger samsung battery
Battery charger samsung battery m02 battery
