이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the plastic midframe.
필요한 것
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
다른 38명이 해당 안내서를 완성하였습니다.
