이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the rear-facing camera.
필요한 것
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Use a plastic opening tool to pry the rear-facing camera connector from its socket.
다른 32명이 해당 안내서를 완성하였습니다.
댓글 3개
Hola es muy bueno el tutoril pero yo tengo un problema y es que la camera de mi samsung galaxy s3 no funciona cuando quiero hacer selfie se bloquea me toca ir a aplicaciones borrar todo sus ajustes para poder usar la de nuevo he probado también con app de otros pero a la hora de hacer selfie se bloquea y toca borrar sus ajustes,por lo demás funciona bien
Is it possible to extend the camera strip for the rear facing camera so it could be taken out of the case and make it forward mounted (as an example)? How would you go about this I have an old s3 and want to adapt it into a hidden spy camera for when I am away to watch the house
I simply followed these instructions and the repair worked perfectly. Many thanks indeed for your help.
