이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unhook the rear using a soft plastic prying tool to remove the rear cover
Be careful not to damage the rear cover when unhooking it.
Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
Disconnecting the camera connector isn't necessary!
After disconnecting the connectors carefully pull the Main PBA out of the bracket.
Make sure that the Power Key FPCB does not get stuck!
Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame
Pull out the Receiver module from the bracket. Be careful not to damage the FPC.
Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
다른 13명이 해당 안내서를 완성하였습니다.
