주요 콘텐츠로 건너뛰기
Samsung Galaxy S Vibrant Loud Speaker Replacement
필요한 것
  1. Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: 1 단계, 이미지 1/3 Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: 1 단계, 이미지 2/3 Samsung Galaxy S Vibrant Loud Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Loud Speaker Replacement: 2 단계, 이미지 1/2 Samsung Galaxy S Vibrant Loud Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Loud Speaker Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Loud Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Loud Speaker Replacement: 5 단계, 이미지 1/3 Samsung Galaxy S Vibrant Loud Speaker Replacement: 5 단계, 이미지 2/3 Samsung Galaxy S Vibrant Loud Speaker Replacement: 5 단계, 이미지 3/3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Loud Speaker Replacement: 6 단계, 이미지 1/2 Samsung Galaxy S Vibrant Loud Speaker Replacement: 6 단계, 이미지 2/2
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Loud Speaker Replacement, Loud Speaker: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    구매
    • Locate the seven screws on the plastic casing.
    • Using the Phillips #00 Screwdriver, remove all seven screws.
    • Be careful not to lose any of these small screws.
  8. Samsung Galaxy S Vibrant Loud Speaker Replacement: 8 단계, 이미지 1/1
    • Once all seven screws have been removed, use the Plastic Opening Tools to gently release the plastic snaps around the seam of the black casing.
    • Be careful not to break any of the plastic snaps.
  9. Samsung Galaxy S Vibrant Loud Speaker Replacement: 9 단계, 이미지 1/1
    • After all the plastics snaps have been released, the black plastic casing will come off easily.
    • Locate the speaker.
  10. Samsung Galaxy S Vibrant Loud Speaker Replacement: 10 단계, 이미지 1/1
    • Using the Plastic Opening Tools, carefully lift the golden-brown clamp holding down the speaker's ribbon cable.
    • Remove the speaker by gently pulling it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Catlin
회원 가입일: 01/15/13
79 평판
안내서 6개 작성하였습니다
Cal Poly, Team 18-37, Regan Winter 2013 Cal Poly, Team 18-37, Regan Winter 2013 회원
CPSU-REGAN-W13S18G37
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 3,020
