주요 콘텐츠로 건너뛰기
Samsung Galaxy S10 Front-Facing Camera Replacement
필요한 것
  1. Samsung Galaxy S10 Front-Facing Camera Replacement, Heat the back cover: 1 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Heat the back cover: 1 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Heat the back cover: 1 단계, 이미지 3/3
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
  2. Samsung Galaxy S10 Front-Facing Camera Replacement, Create an opening gap: 2 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Create an opening gap: 2 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Create an opening gap: 2 단계, 이미지 3/3
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
  3. Samsung Galaxy S10 Front-Facing Camera Replacement, Insert an opening pick: 3 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Insert an opening pick: 3 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Insert an opening pick: 3 단계, 이미지 3/3
    • Heat an iOpener and apply it to the same edge of the phone for two minutes.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts.
    • If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again. The glass is heated enough when it is barely too hot to touch.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
  4. Samsung Galaxy S10 Front-Facing Camera Replacement, Slice through the adhesive: 4 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Slice through the adhesive: 4 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Slice through the adhesive: 4 단계, 이미지 3/3
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
  5. Samsung Galaxy S10 Front-Facing Camera Replacement: 5 단계, 이미지 1/2 Samsung Galaxy S10 Front-Facing Camera Replacement: 5 단계, 이미지 2/2
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  6. Samsung Galaxy S10 Front-Facing Camera Replacement: 6 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement: 6 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement: 6 단계, 이미지 3/3
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
  7. Samsung Galaxy S10 Front-Facing Camera Replacement: 7 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement: 7 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement: 7 단계, 이미지 3/3
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
  8. Samsung Galaxy S10 Front-Facing Camera Replacement, Remove the midframe: 8 단계, 이미지 1/1
    • Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
  9. Samsung Galaxy S10 Front-Facing Camera Replacement: 9 단계, 이미지 1/2 Samsung Galaxy S10 Front-Facing Camera Replacement: 9 단계, 이미지 2/2
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the volume up button.
    • Pry up to loosen the midframe from the phone.
  10. Samsung Galaxy S10 Front-Facing Camera Replacement: 10 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement: 10 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement: 10 단계, 이미지 3/3
  11. Samsung Galaxy S10 Front-Facing Camera Replacement, Disconnect the battery: 11 단계, 이미지 1/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Disconnect the battery: 11 단계, 이미지 2/3 Samsung Galaxy S10 Front-Facing Camera Replacement, Disconnect the battery: 11 단계, 이미지 3/3
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
  12. Samsung Galaxy S10 Front-Facing Camera Replacement, Front-Facing Camera: 12 단계, 이미지 1/2 Samsung Galaxy S10 Front-Facing Camera Replacement, Front-Facing Camera: 12 단계, 이미지 2/2
    • Use the point of a spudger to pry up and disconnect the front-facing camera connector from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Samsung Galaxy S10 Front-Facing Camera Replacement: 13 단계, 이미지 1/1
    • Remove the front-facing camera module.
결론
After you've completed the repair, follow this guide to test your repair.
다른 2명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
249,876 평판
안내서 503개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 45
전체 시간: 4,782
