주요 콘텐츠로 건너뛰기
Samsung Galaxy S21 Screen Protector Replacement
필요한 것
  1. Samsung Galaxy S21 Screen Protector Replacement, Screen Protector: 1 단계, 이미지 2개 중 1개 Samsung Galaxy S21 Screen Protector Replacement, Screen Protector: 1 단계, 이미지 2개 중 2개
    • Remove the phone case and place phone on a flat, clean surface with the screen facing upward.
  2. Samsung Galaxy S21 Screen Protector Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the damaged screen protector carefully.
    • Usually this can be done with fingernails, but a plastic credit card or ID can make removal easier.
  3. Samsung Galaxy S21 Screen Protector Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy S21 Screen Protector Replacement: 3 단계, 이미지 2개 중 2개
    • Clean the phone screen off with an alcohol wipe to remove any fingerprints and dust from the screen.
  4. Samsung Galaxy S21 Screen Protector Replacement: 4 단계, 이미지 1개 중 1개
    • Wipe and dry the phone screen with a microfiber cloth.
  5. Samsung Galaxy S21 Screen Protector Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy S21 Screen Protector Replacement: 5 단계, 이미지 2개 중 2개
    • Use stickers or tape to remove any dust particles that may have settled on the phone screen.
    • Have the new screen protector easily accessible during this step.
  6. Samsung Galaxy S21 Screen Protector Replacement: 6 단계, 이미지 2개 중 1개 Samsung Galaxy S21 Screen Protector Replacement: 6 단계, 이미지 2개 중 2개
    • Peel back the protective layer on the screen protector, and carefully line up the camera cutout with the front-facing camera, laying the top of the screen protector onto the phone screen.
  7. Samsung Galaxy S21 Screen Protector Replacement: 7 단계, 이미지 1개 중 1개
    • Let the rest of the screen protector fall onto the screen, ensuring that the screen protector is square with the phone screen.
  8. Samsung Galaxy S21 Screen Protector Replacement: 8 단계, 이미지 1개 중 1개
    • Press the screen protector into the screen with your fingers, starting in the middle of the screen and working outwards.
  9. Samsung Galaxy S21 Screen Protector Replacement: 9 단계, 이미지 1개 중 1개
    • Work out any bubbles with the scraper/card by applying firm pressure into the screen protector and slowly sliding towards the nearest edge.
결론
Now you have a brand-new screen protector! Enjoy the fresh look.
작성자
2다른 기여자 명과 함께
Philip
회원 가입일: 02/22/24
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 53
전체 시간: 877
