주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Active Front Facing Camera Replacement
필요한 것
  1. Samsung Galaxy S4 Active Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S4 Active Front Facing Camera Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Front Facing Camera Replacement, Battery: 2 단계, 이미지 1/1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  3. Samsung Galaxy S4 Active Front Facing Camera Replacement, MicroSD Card: 3 단계, 이미지 1/1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  4. Samsung Galaxy S4 Active Front Facing Camera Replacement, SIM Card: 4 단계, 이미지 1/1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Front Facing Camera Replacement, Midframe: 5 단계, 이미지 1/1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Front Facing Camera Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 1/2 Samsung Galaxy S4 Active Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the single 0.3mm screw securing the black cover over the camera sensor.
  8. Samsung Galaxy S4 Active Front Facing Camera Replacement: 8 단계, 이미지 1/2 Samsung Galaxy S4 Active Front Facing Camera Replacement: 8 단계, 이미지 2/2
    • Using a pair of precision tweezers, remove the black camera backing.
  9. Samsung Galaxy S4 Active Front Facing Camera Replacement: 9 단계, 이미지 1/2 Samsung Galaxy S4 Active Front Facing Camera Replacement: 9 단계, 이미지 2/2
    • Using a spudger, disconnect the blue press-fit connector by pulling up gently.
    • Lift the front-facing camera out of the device.
결론
Justin Ogihara
회원 가입일: 09/18/17
27,167 평판
안내서 52개 작성하였습니다
EDU Team EDU Team 회원
Staff
7 회원들
안내서 637개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 514
