주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Active MicroSD Card Replacement
필요한 것
  1. Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active MicroSD Card Replacement, MicroSD Card: 2 단계, 이미지 1/1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,901 평판
안내서 89개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,474
