소개
Use this guide to replace the microSD card in a Samsung Galaxy S4 Active.
도구
부품
지정된 부품이 없습니다.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
다른 3명이 해당 안내서를 완성하였습니다.
