주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Active Microphone Replacement
필요한 것
  1. Samsung Galaxy S4 Active Microphone Replacement, Open Back Cover: 1 단계, 이미지 1/2 Samsung Galaxy S4 Active Microphone Replacement, Open Back Cover: 1 단계, 이미지 2/2
    • Use plastic opening tool to pry open back cover.
  2. Samsung Galaxy S4 Active Microphone Replacement, Pull Out Battery: 2 단계, 이미지 1/1
    • Use the plastic opening tool to take out the battery.
    • Remove SD card and SIM card.
  3. Samsung Galaxy S4 Active Microphone Replacement, Remove Plastic Midframe: 3 단계, 이미지 1/3 Samsung Galaxy S4 Active Microphone Replacement, Remove Plastic Midframe: 3 단계, 이미지 2/3 Samsung Galaxy S4 Active Microphone Replacement, Remove Plastic Midframe: 3 단계, 이미지 3/3
    • Unscrew all screws.
    • Pry off midframe with plastic opening tool.
  4. Samsung Galaxy S4 Active Microphone Replacement, Remove Daughterboard: 4 단계, 이미지 1/3 Samsung Galaxy S4 Active Microphone Replacement, Remove Daughterboard: 4 단계, 이미지 2/3 Samsung Galaxy S4 Active Microphone Replacement, Remove Daughterboard: 4 단계, 이미지 3/3
    • Unscrew screws holding daughterboard in place.
    • Carefully remove daughterboard with plastic opening tool.
    • The microphone is embedded in the daughterboard. This means the entire daughterboard must be replaced.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Miguel Labrador
회원 가입일: 09/23/14
736 평판
안내서 2개 작성하였습니다
USF Tampa, Team 12-3, Blackwell Fall 2014 USF Tampa, Team 12-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,454
