주요 콘텐츠로 건너뛰기
소개
In order to do this successfully, you will have to know how to remove up to the motherboard on the phone.
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Use the flat end of a plastic opening tool to disconnect the USB board connector. Disconnect the front-facing camera cable connector. Disconnect the earpiece speaker assembly cable connector.
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Remove the motherboard.
    • Remove the motherboard.
  10. Use the flat end of a plastic opening tool to disconnect the rear-facing camera connector.
    • Use the flat end of a plastic opening tool to disconnect the rear-facing camera connector.
결론
다른 9명이 해당 안내서를 완성하였습니다.
David
회원 가입일: 2014년 09월 23일
290 평판
안내서 1개 작성함
USF Tampa, Team 12-3, Blackwell Fall 2014 USF Tampa, Team 12-3, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,570
