소개
Use this guide to replace the SIM card on your Samsung Galaxy S4 Active.
필요한 것
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the SIM card.
다른 5명이 해당 안내서를 완성하였습니다.
