주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Active SIM Card Replacement
필요한 것
  1. Samsung Galaxy S4 Active SIM Card Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S4 Active SIM Card Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active SIM Card Replacement, Battery: 2 단계, 이미지 1/1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  3. Samsung Galaxy S4 Active SIM Card Replacement, SIM Card: 3 단계, 이미지 1/1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the SIM card.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,898 평판
안내서 89개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 3,801
