주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Active Vibrator Replacement
필요한 것
  1. Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Vibrator Replacement, MicroSD Card: 2 단계, 이미지 1/1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Vibrator Replacement, Battery: 3 단계, 이미지 1/1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Vibrator Replacement, SIM Card: 4 단계, 이미지 1/1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Vibrator Replacement, Midframe: 5 단계, 이미지 1/1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Vibrator Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: 7 단계, 이미지 1/3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: 7 단계, 이미지 2/3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: 7 단계, 이미지 3/3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Vibrator Replacement: 8 단계, 이미지 1/1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Vibrator Replacement: 9 단계, 이미지 1/1
    • Remove the motherboard.
  10. Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: 10 단계, 이미지 1/2 Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: 10 단계, 이미지 2/2
    • Use tweezers to gently remove the vibrator.
결론
다른 3명이 해당 안내서를 완성하였습니다.
atika5656
회원 가입일: 10/21/14
167 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 11
전체 시간: 3,598
