소개
Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
필요한 것
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
다른 99명이 해당 안내서를 완성하였습니다.
댓글 한 개
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
