메인 콘텐츠로 스킵하기
소개
Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
도구
지정된 도구가 없습니다.
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    I snapped the back cover sorry m8
    Daniel Anishchenko - 답글
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above pic and found the divot and was able to take off the rear cover as per the “Step 1 rear cover” instructions.
    Terry Crawford, Jr. - 답글
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - 답글
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
  4. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward. Remove the battery from your phone. Remove the battery from your phone.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    I was able to remove the Samsung Battery with the blue plastic opening tool(AKA: Spudger) as per the Step 4 Battery instructions.
결론
다른 91명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 2012년 10월 18일
374,700 평판
안내서 541개 작성하였습니다
iFixit iFixit 회원
Community
98 회원들
안내서 8,986개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 37
지난 30일: 221
전체 시간: 77,890
