이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
필요한 것
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
다른 99명이 해당 안내서를 완성하였습니다.
댓글 한 개
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
