주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
소개
Click here for the official iFixit guide to disassemble the Galaxy S4 down to the motherboard. The guide you are currently viewing is archived here for historical purposes only.
부품
지정된 부품이 없습니다.
  1. Peel off back of phone Peel off back of phone Peel off back of phone
    • Peel off back of phone
  2. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  3. Remove all 8 screws
    • Remove all 8 screws
  4. Remove Speaker using a thin rigid plastic thing, starting from where the battery nail-hold is located. Remove Speaker using a thin rigid plastic thing, starting from where the battery nail-hold is located.
    • Remove Speaker using a thin rigid plastic thing, starting from where the battery nail-hold is located.
  5. Release clips on the outer rim Release clips on the outer rim Release clips on the outer rim
    • Release clips on the outer rim
  6. Remove clip off of USB port with a flathead screwdriver. Remove clip off of USB port with a flathead screwdriver.
    • Remove clip off of USB port with a flathead screwdriver.
  7. Use a platic knife or flathead srewdriver to gently unplug the cable. Use a platic knife or flathead srewdriver to gently unplug the cable.
    • Use a platic knife or flathead srewdriver to gently unplug the cable.
  8. Use your flathead screwdrive to carefully detatch the Touch and Homescreen Flex cable Use your flathead screwdrive to carefully detatch the Touch and Homescreen Flex cable
    • Use your flathead screwdrive to carefully detatch the Touch and Homescreen Flex cable
  9. Remove the cable Remove the cable
    • Remove the cable
  10. Detach the flex cable Detach the flex cable
    • Detach the flex cable
  11. Completely remove the flex cable Completely remove the flex cable
    • Completely remove the flex cable
  12. Remove the usb complete port
    • Remove the usb complete port
  13. Remove the 3G and GSM antenna cable from the motherboard. Remove the 3G and GSM antenna cable from the motherboard.
    • Remove the 3G and GSM antenna cable from the motherboard.
  14. Lift ports from motherboard Lift ports from motherboard
    • Lift ports from motherboard
  15. Detach this port from the motherboard Detach this port from the motherboard
    • Detach this port from the motherboard
  16. Disconnect main screen cable Don't forget to remove this screw.
    • Disconnect main screen cable
    • Don't forget to remove this screw.
  17. Now you can take off the motherboard
    • Now you can take off the motherboard
결론
다른 8명이 해당 안내서를 완성하였습니다.
AhsAlexFerguson
회원 가입일: 2016년 11월 01일
423 평판
안내서 1개 작성함
This sucked so baaaaaaad.
AhsAlexFerguson - 답글
I found it helpful, though you're right that it could use a lot of work.
You neglected to mention a screw that holds the motherboard to the display assembly. It can be found to the lower right of the headphone jack and should be removed immediately prior to step 17.
To others who may come along, the USB/daughterboard assembly is affixed to the display chassis with mild adhesive. The daughterboard is VERY flexible and should be removed with caution. I used the flat end of a spudger to gently pry the board up from the chassis by going underneath the cabling on the lefthand side.
Thanks!
E West -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,174
