소개
Mit einem Hardwarereset kannst du Softwareprobleme beheben.
Achtung!!! Ein Factory Reset löscht ALLE Daten von deinem Smartphone!!!
동영상 개요
Schalte das Telefon aus und halte "Lautstärke hoch", "Startbildschirm (Home)" und den Einschaltknopf gleichzeitig gedrückt. Wenn das Galaxy Logo erscheint, löse den Einschaltknopf, halte aber die beiden anderen Knöpfe gedrückt.
Löse die beiden Knöpfe wenn der Android System Recovery Bildschirm erscheint. Benutze die Lautstärke hoch/runter Knöpfe, um im Menü zu navigieren. Der Einschaltknopf ist für die Bestätigung (OK). Wähle "wipe cache partition" aus und bestätige "delete all user data" und anschliessend "reboot system now"
Diese Anleitung benötigt keinen Wiederzusammenbau.
다른 283명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 31개
Here my recommendation is a data eraser named Android Data Eraser, which can erase all Android data including contacts, messages, call history, apps, system setting, photo, video, etc. Indeed, Android Data Eraser worth trusting and it makes the work more effective. What you need is a windows computer. One single click and data deletion finish.
easy to follow instructions but does not work have done it 3 times now and get to a step which requires to do a factory reset. Phone the automatically switches off and loses connection with program and have to start all over again. Goes round in circles with a factory reset the only result - and you can do that without downloading the program.
why would you bother when you can factory reset in 1 min???
Deleted data from samsung phone are recoverable with Coolmuster Samsung Recovery software. But you need to follow special steps as droid phone`s memory is not accessible easily.
Swolsteedd - 답글
Hi Can the software recover my calendar after I mistakenly did a factory wipe?
