소개
Use this guide to replace the headphone jack assembly, including the status light and infrared sensor, in your Samsung Galaxy S4.
필요한 것
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the SIM card.
Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
I agree with the comment above
I also don't have a plastic tool and my finger nail won't pop the card out.
Grethe Montano. September 22
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
How much cost will be on replace a midframe
I purchased a 1.5x40mm Phillips screw driver and was able to remove all 9 40mm screws from the midframe as per the Step 6 Midframe instructions.
Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
Slide the opening tool along the seam, separating the plastic clips as you go.
I used same tool as in the photo and i broke the display. I think you should use a very thin plastic tool, such as a credit card but even more thin and flexible.
I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9.
Continue prying around the corner of the phone.
Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
On my phone, there was another clip holding the white midframe to the battery compartment, in the middle of the top edge of the battery compartment, near the battery contacts. If you don't release that before removing the midframe, it is easy to break.
I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them.
Remove the midframe from the display assembly.
My Sprint S4 was slightly different then the one pictured above but I just completed this repair in under 10 minutes.. It would have been slightly quicker but fooling around with those little screws can be irritating if you have big hands.
Use the flat end of a spudger to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Disconnect the headphone jack assembly cable connector.
Disconnect the display/digitizer cable connector.
Disconnect the antenna cable connector.
My model had an antenna connection next to the usb board connector in addition to the antenna connection near the display cable connector.
That's point a, on the daughter board (where the USB is located is point b. You must connect it from a to b
I could not get the screen connector to fit on with the motherboard assembly in place. I had to remove the motherboard assembly, attach the screen connector, and then carefully replace the motherboard assembly, with the screen connector still attached..
Same as Tom4G above. When trying to connect the screen connector, it would not give me that nice clear snap indicating a positive connection. The phone powered up with no screen. So, I disconnected the other connectors again, lifted the motherboard out and connected the screen connector by pinching it with finger and thumb from both sides of the motherboard, this time getting a nice snap when it engaged.
speedrzr -
Remove the single 2.4 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
Remove the headphone jack assembly.
I had a quick question there's a little white rubber circular gasket piece that the headphone jack covers up
What's that piece called?
The small rectangular milky-white silicon gasket appears to be a diffuser for ambient light sensor. I removed it with a small screwdriver, and replaced it in the same location in my new screen assembly.
The small rectangular milky-white silicon gasket appears to be a diffuser for an ambient light sensor. I prised it out of the old assembly and placed it in the new screen assembly. I also started transferring the components as they were removed from the old screen, so the head-phone jack went straight into the new at this point. I may regret that later…
The angle of the picture here makes it appear like the head phone jack needs to be slid out of the top of the phone. This is impossible due to small bits of plastic holding it in at the top. If you're having trouble, the headphone jack is in fact supposed to lift straight up out of the phone.
Additionally, there might be a small amount of adhesive holding the headphone jack to the board (there was some in my device). Apply a bit of heat to loosen it up, if needed.
it is easy to pop off, if you apply pressure to the right point. Using a plastic pair of tweezers or a pry tool, push at the lower right corner and gradually increase the pressure, if you apply enough pressure it will just pop right off.
다른 37명이 해당 안내서를 완성하였습니다.
댓글 8개
I accidentally inserted an electric pin instead of the auxiliary jack into the head phone jack assembly. There was a loud screeching sound and ever since then the head phones do not work. However, I can play music through the phone speaker and also with Bluetooth. I cannot listen to music with my ear buds or head phones or with auxiliary speakers. I have replaced the jack assembly with a new one and yet it is the same. What more can I do to rectify this?
Did you ever get help on this? Having the same problem.
Me too have same problem....did u got it fixed or not?...if yes how u did it...?
reone -
I too am having this issue. I assume we have fried the amp for external audio with wtv current we happened to let touch our aux ports. Sounds like I bigger issue to fix. Just still wondering if I can.
Where do you even get the part?
Thanks to Sam Lionheart for this guide. It was clear and easy to follow. It gave me the instructions I needed to solve my problem - headphones etc. were no longer making good connections with my Galaxy S-4 jack - and for about $7 I was able to completely fix the issue.
