주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 MicroSD Card Replacement
필요한 것
  1. Samsung Galaxy S4 MicroSD Card Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S4 MicroSD Card Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 MicroSD Card Replacement: 2 단계, 이미지 1/3 Samsung Galaxy S4 MicroSD Card Replacement: 2 단계, 이미지 2/3 Samsung Galaxy S4 MicroSD Card Replacement: 2 단계, 이미지 3/3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: 3 단계, 이미지 1/3 Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: 3 단계, 이미지 2/3 Samsung Galaxy S4 MicroSD Card Replacement, MicroSD Card: 3 단계, 이미지 3/3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,777 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
If you use Micro SD card the you must know to How to Recover Memory Card
we are not going to use any app/softwares we only use CMD and 5 exclusive methods
http://www.gogorapid.com/how-to-recover-...
Ramal jayaratna - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 16
30일 전: 43
전체 시간: 87,541
