주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Midframe Replacement
필요한 것
  1. Samsung Galaxy S4 Midframe Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Galaxy S4 Midframe Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Midframe Replacement: 2 단계, 이미지 1/3 Samsung Galaxy S4 Midframe Replacement: 2 단계, 이미지 2/3 Samsung Galaxy S4 Midframe Replacement: 2 단계, 이미지 3/3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 Midframe Replacement, MicroSD Card: 3 단계, 이미지 1/3 Samsung Galaxy S4 Midframe Replacement, MicroSD Card: 3 단계, 이미지 2/3 Samsung Galaxy S4 Midframe Replacement, MicroSD Card: 3 단계, 이미지 3/3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Galaxy S4 Midframe Replacement, Battery: 4 단계, 이미지 1/3 Samsung Galaxy S4 Midframe Replacement, Battery: 4 단계, 이미지 2/3 Samsung Galaxy S4 Midframe Replacement, Battery: 4 단계, 이미지 3/3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Samsung Galaxy S4 Midframe Replacement, SIM Card: 5 단계, 이미지 1/3 Samsung Galaxy S4 Midframe Replacement, SIM Card: 5 단계, 이미지 2/3 Samsung Galaxy S4 Midframe Replacement, SIM Card: 5 단계, 이미지 3/3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  6. Samsung Galaxy S4 Midframe Replacement, Midframe: 6 단계, 이미지 1/1
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  7. Samsung Galaxy S4 Midframe Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S4 Midframe Replacement: 7 단계, 이미지 2/2
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
  8. Samsung Galaxy S4 Midframe Replacement: 8 단계, 이미지 1/2 Samsung Galaxy S4 Midframe Replacement: 8 단계, 이미지 2/2
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Midframe Replacement: 9 단계, 이미지 1/2 Samsung Galaxy S4 Midframe Replacement: 9 단계, 이미지 2/2
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Midframe Replacement: 10 단계, 이미지 1/2 Samsung Galaxy S4 Midframe Replacement: 10 단계, 이미지 2/2
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  11. Samsung Galaxy S4 Midframe Replacement: 11 단계, 이미지 1/3 Samsung Galaxy S4 Midframe Replacement: 11 단계, 이미지 2/3 Samsung Galaxy S4 Midframe Replacement: 11 단계, 이미지 3/3
    • Remove the midframe from the display assembly.
결론
다른 93명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
467,548 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,074개 작성하였습니다
댓글 5개
I cracked the "front facing" bezel on my phone. I thought buying a new mid frame would replace it, but based on these pictures, it looks like it is attached to the the front glass. Is this correct? Is there any way to replace just that front facing bezel?
Marwan - 답글
i was wondering the same thing. Can you guys please respond.
Rival Archer -
Yes, the bezel is attached to the front glass. Replacing the glass doesnt cost too much (under 15 eur here) but theres a high chance you will break the lcd digitizer in the process. It needs some skill.
Mark Bernstein -
Hi... Is that the whole body is model GT-I9505 and How much it costs me the whole body?
Priya - 답글
Hi.. Is that the whole body is with mirror and how much it costs me??
Priya - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 17
전체 시간: 130,081
