주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
필요한 것
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: 1 단계, 이미지 1/1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 2 단계, 이미지 1/1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 3 단계, 이미지 1/1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 4 단계, 이미지 1/2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 4 단계, 이미지 2/2
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: 5 단계, 이미지 1/1
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: 6 단계, 이미지 1/1
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 7 단계, 이미지 1/2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 7 단계, 이미지 2/2
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 8 단계, 이미지 1/1
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 9 단계, 이미지 1/2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 9 단계, 이미지 2/2
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 10 단계, 이미지 1/2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 10 단계, 이미지 2/2
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 11 단계, 이미지 1/2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 11 단계, 이미지 2/2
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 12 단계, 이미지 1/3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 12 단계, 이미지 2/3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 12 단계, 이미지 3/3
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 13 단계, 이미지 1/2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 13 단계, 이미지 2/2
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Richard
회원 가입일: 02/07/17
29,922 평판
안내서 11개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,734개 작성하였습니다
댓글 한 개
Thank You so much!
Peter Handless - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 24
전체 시간: 5,175
