주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
필요한 것
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: 1 단계, 이미지 1개 중 1개
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 2 단계, 이미지 1개 중 1개
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 3 단계, 이미지 1개 중 1개
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 4 단계, 이미지 2개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: 5 단계, 이미지 1개 중 1개
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: 6 단계, 이미지 1개 중 1개
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 7 단계, 이미지 2개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 7 단계, 이미지 2개 중 2개
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 9 단계, 이미지 2개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 9 단계, 이미지 2개 중 2개
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 10 단계, 이미지 2개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 10 단계, 이미지 2개 중 2개
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 11 단계, 이미지 2개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 12 단계, 이미지 3개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 12 단계, 이미지 3개 중 2개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 12 단계, 이미지 3개 중 3개
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 13 단계, 이미지 2개 중 1개 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 13 단계, 이미지 2개 중 2개
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Richard
회원 가입일: 02/07/17
34,341 평판
안내서 11개를 작성함
1가이드 댓글
Thank You so much!
Peter Handless - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 29
전체 시간: 5,860
