소개
If you're finding that you cannot install anything new or save any pictures it is most likely due to the fact that the memory card on the phone is full.
필요한 것
Remove the back cover of the cell phone using a plastic opening tool.
The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
Does “slide it out” refer to memory card holder or the memory card itself?
Photo useless. Cannot see where “hole” is.
다른 3명이 해당 안내서를 완성하였습니다.
