주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 Mini Speaker Replacement
필요한 것
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Speaker Replacement: 3 단계, 이미지 1/1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: 4 단계, 이미지 1/2 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: 4 단계, 이미지 2/2
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: 5 단계, 이미지 1/1
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: 6 단계, 이미지 1/3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: 6 단계, 이미지 2/3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: 6 단계, 이미지 3/3
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: 7 단계, 이미지 1/2 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: 7 단계, 이미지 2/2
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: 8 단계, 이미지 1/1
    • Insert the new loud speaker
결론
다른 31명이 해당 안내서를 완성하였습니다.
Luis Ojeda
회원 가입일: 09/23/14
989 평판
안내서 1개 작성함
USF Tampa, Team 9-2, Blackwell Fall 2014 USF Tampa, Team 9-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G2
5 회원들
안내서 11개 작성하였습니다
댓글 3개
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - 답글
perfect. thankyou
rick bailey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 13,786
