주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 - Password, Screen Lock Removal
동영상 개요
  1. Samsung Galaxy S5 - Password, Screen Lock Removal, Samsung Galaxy S5 - Password, Screen Lock Removal: 1 단계, 이미지 3개 중 1개 Samsung Galaxy S5 - Password, Screen Lock Removal, Samsung Galaxy S5 - Password, Screen Lock Removal: 1 단계, 이미지 3개 중 2개 Samsung Galaxy S5 - Password, Screen Lock Removal, Samsung Galaxy S5 - Password, Screen Lock Removal: 1 단계, 이미지 3개 중 3개
    • If you forgot you password, pattern drill, there are three ways to bypass the security:
    • You can log-in on your phone by Google account registered on this phone. You must be connected to a WiFi network that you have used before.
    • By entering Backup PIN, if you had created one before.
  2. Samsung Galaxy S5 - Password, Screen Lock Removal: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S5 - Password, Screen Lock Removal: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S5 - Password, Screen Lock Removal: 2 단계, 이미지 3개 중 3개
    • - Turn off the phone.
    • - Press and hold at the same time Volume UP,Home and Power keys.
    • - When you see Galaxy logo release the Power key but continue to hold the Volume Up key and the Home key.
    • - Release them when the Android System Recovery screen appears.
    • - Use the Volume Up/Down keys for navigation and the Power On key for OK.
    • - Choose "wipe cache partition", "Yes -- delete all user data", "reboot system now".
    • - That's all.
    • Please SUBSCRIBE to my channel ツ
결론
다른 200명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,826 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
49가이드 댓글
Very easy steps to follow, and it worked perfectly. Life saver, thanks a lot.
Scootie - 답글
To remove your screen lock on Samsung, this article gives three methods:
Lucious Nicole -
I did a factory hard reset, and it requires me to enter my samsung account information. I know what that information is, but for some reason samsung has no record of me! I don't think it will do me any good to re-do the factory hard reset. I'm being told I now have a paper weight. Any other ideas to bypass this?
Penny Maurer -
@Penny, if you can’t use this way to unlock Samsung phone password, you can try another method to unlock Samsung phone password, with Samsung Unlock, you can unlock Samsung password in several clicks, and detailed guide, easy operation.
Salim -
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 288
지난 30일: 994
전체 시간: 809,136
