소개
The removal of the motherboard is a time consuming process. It involves the removal of most components from the phone. It also involves the use of a few tools such as a guitar pick, a heat gun, tweezers, a screwdriver, and plastic opening tools. You should be aware of the hazards and safety procedures of all tools before starting the process.
필요한 것
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
Use your finger or a plastic opening tool to disconnect the proximity/light sensor from the motherboard.
Use tweezers to gently pull the proximity/light sensor out.
다른 19명이 해당 안내서를 완성하였습니다.
