소개
The removal of the SIM card is a very simple process and tools are required to complete the objective. You can also use this guide to remove the MicroSD card. The MicroSD card would follow the same procedure as the SIM card since it goes in the slot that is just on top.
필요한 것
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
다른 8명이 해당 안내서를 완성하였습니다.
Great looking guide with well lit pictures and very concise bullet points.
Rusbell Gonzalez - 답글
