주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 Home Button Replacement
필요한 것
  1. Samsung Galaxy S5 Home Button Replacement, Home Button: 1 단계, 이미지 1개 중 1개
    • This guide is a conditional add-on to the Galaxy S5 Display Assembly guide. If you need to replace your home button but have not yet opened your device, start here.
    • The clear rubber backing of the home button assembly is lightly adhered to the back of the display. The adhesive should be easy to cut through with an opening tool. If you have trouble removing the assembly in the following steps, try heating the area using an iOpener or a hair dryer to loosen the adhesive.
  2. Samsung Galaxy S5 Home Button Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S5 Home Button Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S5 Home Button Replacement: 2 단계, 이미지 3개 중 3개
    • Insert either end of an opening tool into the gap between the white rubber backing of the home button assembly and the screen.
    • Work your way around the bottom edge of the button, gently cutting through the adhesive holding it in place.
  3. Samsung Galaxy S5 Home Button Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy S5 Home Button Replacement: 3 단계, 이미지 2개 중 2개
    • Once most of the adhesive around the bottom of the button has been broken, use your opening tool to pry it up.
  4. Samsung Galaxy S5 Home Button Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S5 Home Button Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S5 Home Button Replacement: 4 단계, 이미지 3개 중 3개
    • Grab the lifted portion of the home button assembly and gently pull it away from the display, tearing the rest of the adhesive.
    • As you pull the assembly away, the rubber backing may begin to separate from the home button. The home button is only connected to the rubber backing by a fragile cable, so do your best to keep them together as you pull the assembly out.
    • If you are transferring your home button to a new display, the original adhesive should be strong enough to keep it in place.
    • If the original adhesive is not strong enough to hold the button in place while you re-install the display, you can lay the button in the chassis, and then install the display over it—the display assembly will keep the button in place.
    • If you are installing a new home button, remove the plastic film covering the adhesive, then carefully align the button with the display and press it into place.
결론
To finish reassembling your device, head back over to the Display Assembly guide!
다른 8명이 해당 안내서를 완성하였습니다.
Taylor Dixon
회원 가입일: 06/26/18
71,614 평판
안내서 94개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 31
전체 시간: 6,622
