주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 Mini SIM & SD card reader Replacement
필요한 것
  1. Samsung Galaxy S5 Mini SIM & SD card reader Replacement, SIM & SD card reader: 1 단계, 이미지 1/1
    • Remove back cover.
  2. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 2 단계, 이미지 1/1
    • Remove battery. If you have SIM card and SD card in, remove them by the way.
  3. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 3 단계, 이미지 1/2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 3 단계, 이미지 2/2
    • Open this cover and release the home button flex connector.
  4. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 4 단계, 이미지 1/3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 4 단계, 이미지 2/3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 4 단계, 이미지 3/3
    • Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker.
  5. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 5 단계, 이미지 1/2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 5 단계, 이미지 2/2
    • Remove the LCD screen from rear case.
  6. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 6 단계, 이미지 1/2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 6 단계, 이미지 2/2
    • Remove all the screws.
  7. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 7 단계, 이미지 1/2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 7 단계, 이미지 2/2
    • Get loosen the touch keys from adhesive, and then push the mid-plate out from the middle housing.
  8. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 8 단계, 이미지 1/2 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 8 단계, 이미지 2/2
    • Twist off these two screws and remove the whole motherboard assembly.
  9. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 9 단계, 이미지 1/3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 9 단계, 이미지 2/3 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: 9 단계, 이미지 3/3
    • Release the connector,loose the assembly from adhesive and remove it finally.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 5,275
