주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 SIM Card Replacement
필요한 것
  1. Samsung Galaxy S5 SIM Card Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy S5 SIM Card Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy S5 SIM Card Replacement, Rear Case: 1 단계, 이미지 3/3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 SIM Card Replacement, Battery: 2 단계, 이미지 1/3 Samsung Galaxy S5 SIM Card Replacement, Battery: 2 단계, 이미지 2/3 Samsung Galaxy S5 SIM Card Replacement, Battery: 2 단계, 이미지 3/3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
  3. Samsung Galaxy S5 SIM Card Replacement, microSD Card: 3 단계, 이미지 1/2 Samsung Galaxy S5 SIM Card Replacement, microSD Card: 3 단계, 이미지 2/2
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
  4. Samsung Galaxy S5 SIM Card Replacement, SIM Card: 4 단계, 이미지 1/1
    • Repeat the above procedure to remove the SIM card.
결론
다른 34명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,970 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 3개
Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface.
Chris Ward - 답글
"Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface"
Good suggestion. Alternatively..........use a pencil eraser!
johnsg0053 - 답글
Why is my galaxy s5s screen black..I can get the buttons to light up but the screen won't come on..
Misti Weatherwalk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 167
전체 시간: 61,410
