소개
Use this guide to remove the SIM card.
필요한 것
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot.
Remove the microSD card from the phone.
다른 34명이 해당 안내서를 완성하였습니다.
댓글 3개
Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface.
Chris Ward - 답글
"Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface"
Good suggestion. Alternatively..........use a pencil eraser!
johnsg0053 - 답글
Why is my galaxy s5s screen black..I can get the buttons to light up but the screen won't come on..
