주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 SIM Card Replacement
필요한 것
  1. Samsung Galaxy S5 SIM Card Replacement, Rear Case: 1 단계, 이미지 1/3 Samsung Galaxy S5 SIM Card Replacement, Rear Case: 1 단계, 이미지 2/3 Samsung Galaxy S5 SIM Card Replacement, Rear Case: 1 단계, 이미지 3/3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 SIM Card Replacement, Battery: 2 단계, 이미지 1/3 Samsung Galaxy S5 SIM Card Replacement, Battery: 2 단계, 이미지 2/3 Samsung Galaxy S5 SIM Card Replacement, Battery: 2 단계, 이미지 3/3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
    The battery will need to be charged after it is placed in the phone. No one told me that and I bought a battery and thought it was bad. Keep the phone off and insert the charger. You will need to charge it for several hours before you can use the phone.
    Diane Schumacher - 답글
  3. Samsung Galaxy S5 SIM Card Replacement, microSD Card: 3 단계, 이미지 1/2 Samsung Galaxy S5 SIM Card Replacement, microSD Card: 3 단계, 이미지 2/2
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
    I found removing the SIM/SD card with my fingertip a little difficult – not enough friction. So I used a 'rubber' (in US English it's called a pencil eraser or just simply, an eraser.
    Simple, cheap (zero) and effective! :)
    Cheers.
    John
    johnsg0053 - 답글
  4. Samsung Galaxy S5 SIM Card Replacement, SIM Card: 4 단계, 이미지 1/1
    • Repeat the above procedure to remove the SIM card.
    Actually this isn’t as easy as it appears in the photo and instructions, since the SIM card does not have a notch that you can use to pull it out. In my experience I’ve found that the best way to remove the SIM card is by pressing down somewhat hard on the SIM card, and then push-pulling it outward.
    OmniWeb Technical Education - 답글
결론
다른 34명이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,780 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 3개
Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface.
Chris Ward - 답글
"Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface"
Good suggestion. Alternatively..........use a pencil eraser!
johnsg0053 - 답글
Why is my galaxy s5s screen black..I can get the buttons to light up but the screen won't come on..
Misti Weatherwalk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 33
30일 전: 173
전체 시간: 61,334
